chilibean's avatar
chilibean
Any fixes for Dometic SS fridge door severley scratched
Hi All,
I have a 2007 Dometic Refrigerator model RM3962 with wrap around Platinum Stainless Steel. The door got a nasty scratch in it, and me being the DIY I am, I decided to try to fix it. Um, nope! Made it oh-so-much worse. Dometic quoted me $986.00 plus shipping:E for a set, but I only need the fridge section. I have not called local RV dealers yet to find out if they can order me one because I know that will still be a lot of $$$. I was thinking about the Thomas Stainless Steel paint, but there are mixed reviews on that, plus it would not be anywhere near the color of the freezer door. I called a local appliance repair shop but they would not touch it. My thinking is now maybe replacing both the panels, but I am not sure if I can do that with the current wrap around. Has anyone here replaced door panels? Or, does anyone have any other ideas? I have lost sleep over this, and feel sick to my stomach every time I look at it. Searching the internet I know I am not alone in ruining a ss door, but that is little comfort knowing this might be a horribly expensive fix. Any ideas or insights are welcome.
Sharon
  • chilibean wrote:
    OK, good idea. This is why I love this forum :) Now to find one.
    And yes, adding a panel to the center might work too. It is only the face that is damaged. I have also seen online that there are skins that can be applied, some with designs, but not sure how they would look in person.
    Maybe you won't even need to cut the center section out, just over-lay it with something & add trim.
  • How DIY friendly are you with metal work? You could probably put a brushed finish on the door panel that would eliminate most of the scratch or botched repair job.
    Can you post a picture of the door panel?
  • OK, good idea. This is why I love this forum :) Now to find one.
  • If the wrap around portion is not damaged, maybe it's possible to cut out the center section of the door a couple of inches or so from the wrap all the way around, adding some kind of trim & a new accent center panel in between.
