down_home
Mar 22, 2020Explorer II
Several years ago we had all four new tires on our F150 go bang, at different times. China junk valve stems. The Dealer and Distributor replaced all four tires. There are probably still some china junk valve stems without UV protection still around.. Second you may have damaged the valve core with a defective plastic valve stem cap. We had a leak on left front on the MH. It was the valve stem being loose. The good stainless caps used on large tire high pressure tires on Mhs and Trucks kept the pressure in,until the pressure was checked and apparently didn't reseal as good.
We had a different problem with our Fifth Wheel tire stems, rubber with brass tube inside someone stepped on and bent/broke them inside and they all leaked.
We replaced them with bolt on or in short stainless valve stems and caps. I would recommend the short stainless valve stems and caps if they will work or a slightly longer one if necessary.
