kabbro's avatar
kabbro
Any hints about why my tire leaking?
Trailer has been in storage lot in Florida for 3 months, want to leave the state tomorrow so yesterday I checked systems out and was pleased to learn that all 4 trailer tires were still at 50# as required and didn’t need inflation. When I was putting the plastic valve cap back on it seemed like I turned it too far and popped the top of the cap...I did not move the trailer at all yesterday. When I went down this am to hook up, that tire was flat. (Just wanted to emphasize that the trailer and tire was NOT moved yesterday). I have reinflated the tire twice and it slowly leaks. I have done the soap suds routine and there is no evidence of leaking (bubbling air) through the valve stem. I don’t have the jack to change the tire myself and haven’t been able to get any road service to come out...needless to say we won’t be leaving Florida tomorrow morning as planned. Just wondering if any readers can help me diagnose the likely source of the air leak.Thanks.
  • You twisted the stem where it enters the rim when you cranked down on the valve cap. real simple. Take it and have a new stem put in. I got rid of all those cheap azzed import fake rubber valve stems years ago. They all take a puke eventually, some sooner some later but they all fail.
    Get yourself some screw down metal racing stems. One time replacement. Last forever.
  • Metal valve stems aren't even remotely required, although they may be personally preferable, they are not foolproof either.
    Even 8 lug trucks come with rubber valve stems these days.
    How old are the tires and valve stems? Likely didn't catch the bad valve stem with your soap test.
    Another option, if you're in a hurry and don't want to bust the tire off the rim is replace the bad valve stem with a Colby valve. Can get em next day Amazon prime and some good auto parts stores carry them. Very handy. I have one with my on the road tools.
    They are a compression fitting valve stem and very robust.
  • WHOAH WATCH OUT THERE.
    you are describing the way my stems on my flat bed acted when they got rotten. I would grab that stem and twist it around some (with my fingers of course) and see if it starts hissing where it comes through the rim. put some soap solution there also.
    If that stem is rotten, I would suggest that the other ones are ready to expire also. :h
  • yes, the plastic caps just keep dirt out, and do nothing to hold air in. as suggested you probably moved the old dry rot valve. Those need replacing every few years anyway. Usually when you get new tires.
    There are metal caps with rubber washers that do hold air in so adds another barrier to a leak.
    There is a product I have used for tire leaks (not valve leaks) that creates an airtight seal from the inside. Monster Energy Drink desert racers are sponsored by it and swear to it. It works in my lawnmower tire too and has held a leaky tire up for two years so far.
    Truckerco is the product. Unlike Slime that kind-of works at lower psi, this is a latex product that bonds to the tire, will fill in holes or leaks and has done wonders for me and works at 80psi in my truck.
    I have seen it on ebay, straight from the company in NV, but Amazon probably not shipping bc of virus right now (Amz only shipping essentials).
