shum02 wrote:
greatwhitenorth69 wrote:
I used to use antifreeze but could always taste it for the entire season.
After the winter when I'm finally ready to de-winterize for the spring/summer/fall season I do a rinse of water/bleach through the lines then another with vinegar to neutralize the taste of bleach then after that plain old tap water.
..Rinse with bleach, then rinse with vinegar to neutralize bleach, then one more rinse with water to clear it all out, every time you de-winterize. Wow.
Or, if you just blow out the lines, do NONE of that, and just GO when you want to, no flushing out of any kind necessary, and no bad taste from the water.
I think this highlights very clearly why many of us chose to use the blow-out method, and shows why its not just about the $4 saved in antifreeze. Its about having basically ZERO de-winterizing to do when you're ready to camp again.
Like I said before, if compressor blow-out is good enough for the RV manufacturers themselves and is what THEY use, AND its good enough for RV technicians that are contracted to winterize units that sit permanently up in the mountains (where it gets quite cold) all year....Welllll, it should be good enough for all of us.
This thread did remind me it was time to get the winterizing done, so I went ahead and got our Motorhome Saturday, same way I always have, using air compressor. Did some experimenting some with air pressure this time. Did it inititally with the compressor's dial set at 35 psi, then did it again at 50. I definitely noticed at 35 psi, you still can hear 'gurgling' coming from the pipes when opening faucets. You don't get all the water out with just 35 psi. When I did it at 50, it pushed a bit more water out, then no more gurgling. Cleared the pipes out much better.
'Twas a good reminder why I've always used 50 psi when blowing out the lines, and why we've never had an issue with this approach.
Will be wonderful when we decide to head out camping next time, to just throw some clothes, food, etc. in the Motorhome and go. No need to fool with plumbing at all. :)
