- Jack_SprattExplorer50# on each side on my E450 class c
- garyhauptExplorerYou have to fill yours manually...there is an option. One I took. Mine too, came with valve stems. Still there. I had the air bag compressor installed. Gauge on the plastic stuff under the dash with the control buttons..one on each side. Looks down right spiffy..plus, I don't have to stand out in the weather to check and fill..and I can do it as roll.
https://www.google.com/search?client=firefox-b-d&q=air+bag+compressor
Gary Haupt - DrewEExplorer IIWith my class C, I find about 40 psi works out best for the air helper springs.
If they're Firestone ride-rite units, you're supposed to have I think a minimum of 10 or 15 psi, and no more than 90 psi. The volume of air requied is qutie small; a bicycle hand pump is easily able to adjust them as needed, while a large compressor can be a bit too fast if you're not careful. Even checking the pressure with a standard tire gauge can lower it a half pond or a pound, which is sometimes handy for fine-tuning if you care about that level of (probably unnecessary) precision.
It should be pretty obvious what works reasonably well when driving around. Too little, and you'll feel rather like it's wallowing around on bumps and dips; too much, and you're driving on rocks. You can also gauge by ride height (which is what they intend, really), but it's really really hard to get a pre-load ride height for a motorhome since the majority of the load is bolted or welded to the chassis before you get it. - Grit_dogNavigator IITypically air bags are fixed top and bottom and don't float, so not sure what you got going on under your Winnebago.
However, the PO likely installed them because they thought it was overloaded or too soft of rear suspension.
You say it's not sagging, which in general, means you don't need anything to help the suspension.
Why not drive it no air, then 20psi, then 40 psi or whatever and see what feels best? - RollandBExplorerI put air bags on my previous truck to level the ride when towing. Had a fill for each side if I ever needed them different.
My current truck came with Timbrens which I prefer to the bags. No harsh ride when empty and no baby sitting the pressure in the bags. - ZINGERLITEExplorer
Optimistic Paranoid wrote:
Generally speaking, with airbags, if there is only ONE air fitting to feed both bags, when you go around curves, and the motor home leans, it will force air from one of the bags over to the other side. A lot of people feel it's better that each bag has it's own separate air line. In addition to preventing this, it allows you to put more air into one side or the other to adjust for side-to-side weight differences.
BTW, is there air in them now? How much? Is your motor home level?
That's the best way. I've got a slammed project truck with air ride suspension and each bag has separate valves for this exact reason. - djfrownExplorerI have a 2010 GMC 2500HD 6.0L that I tow a Koala 26Qi with that has air bags and auto-sensing Bilsteins front shocks. I use ~15 psi when empty and ~45 when towing. The ride is smooth.
- badsixExplorerI have a 2010 GMC that I tow a 27 T/T, with it hooked up ready to go with water the truck is almost and inch low in the back. I air up my bags with about 15- 18 psi just to were the truck starts to raise about 1/2 - 3/4 inch. it makes the ride so much better, stops a lot of the porpoise effect.
Jay D. - doxiemom11Explorer IIPrevious had rear air bags on a GMC Envoy. It had it's own built-in-compressor and automatically adjusted the ride height based on the load in the rear-end. There was a valve on the airbag, but we didn't have to do anything with the valve or put air in/out.
- luberhillExplorer
There is two separate valves
Don’t think there is air now they are not touching the springs, it is level
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
