- rhagfoExplorer III
RinconVTR wrote:
Plenty are towing 5th wheels with Tundra's.
Rear axle weight and Gross combined rating should be adhered to.
Otherwise, IMO towing a 5th wheel that maxes out the Tundra is FAR better than towing a bumper pull TT near or even under max. And I tow a 7000lb TT with a Sequoia...so don't try to tell me I don't know what I'm talking about!!!!
X2
To the 5er over a TT, just naturally more stable! - RinconVTRExplorerPlenty are towing 5th wheels with Tundra's.
Otherwise, IMO towing a 5th wheel that maxes out the Tundra is FAR better than towing a bumper pull TT near or even under max. And I tow a 7000lb TT with a Sequoia...so don't try to tell me I don't know what I'm talking about!!!! - trikeflyerExplorerOk, so from first-hand experience, I did pull a 30' 5th wheel for 8 years over many thousands of miles with a 03 tundra. That being said I did add air bags and a transmission cooler. The 5er was a ultra-lite and under 8k dry weight. There were times in the mountains that it felt that it was all it could do to go over the mountain but it always made it. I did have a slider hitch in the 6' bed but only used it on one or two occasions. If you are looking for approval from the weight police it will never happen.
- carpetguy2ExplorerGot him convinced .He traded his tundra in on a new dodge ram 2500 .Not a dodge guy but its a nice trick.
Thanks for all the feedback and help - tatestExplorer IIA friend of mine did this with a 28-ft 12,000 pound fiver behind his Tundra for three years, about 20,000 miles, without incident. The truck came with load range D tires, which he filled to max sidewall pressure on the rear (rather than the lighter doorpost setting) and he put on helper springs. Was the truck overloaded? Yes. Was it fatal to truck, trailer or occupants? No.
I told him his truck was badly overloaded. He did OK anyway. But his experience led him to trading for a Class C motorhome. - TundraTowerExplorerOn our 2 trips out west, we have seen several Tundra's pulling 5th wheels. I've tried to talk to every one I could. They all have air bags on the rear and all of them had the TRD supercharger added.
The truck will certainly "do it", but not within the factory specifications. Tundra's have very little official payload capacity. Mine rated to pull 9,500 lbs, and it does that quite well, but it officially has less than 1000 lbs of payload capacity on the truck itself. - ncrowleyExplorer IIWe towed with a Tundra and we had a 5K trailer. That was the most I would want to tow with that truck. It did the job but struggled up the mountains out west. You can answer your own question: Look at the tow rating and the weight rating and then look at the weights of the fifth wheel you are considering.
- Grit_dogNavigator IIII'm not the weight cops either, but if I could buy a new fiver, I would buy a truck that would tow it well. The tundra will s uck with that big a trailer. It's not all about the weight, also wind resistance and 5vres are about the biggest sail out there you can hook to a truck.
Caveat, you didn't say how much or how far he wants to tow. We all assume he's goin full time, burnin up the hiways, hittin the Ike at 3 am hammer down.......but if it's to haul it to a nearby long term site and back each year or local, low altitude, flat land short trips then the tundra may do ok. Not great, but ok. - Bob_E_ExplorerI stayed at a campground where the "host" towed a Montana 5th wheel with his Tundra. He really only moved the camper twice a year but that was from Ohio in the summers to Florida in the winters. He said it pulled great! But that don't make it right.
- goducks10ExplorerI've seen two doing it, so I guess it can be done.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
