JBarca
Jan 10, 2014Nomad II
hbensley wrote:
I've used 1/2" pvc pipe the length of which is equal to your travelling RV height. I had two pieces joined with a connector. This means you have to get out and manually check for clearance.
Place one end on the ground under the clearance in question; if the other end clears it then you are good to go. Personally I've only used this in campgrounds for tree limb clearance. This was in the Trailer Life mag a few years ago.
That is good idea!! Simple and very effective. Thanks for sharing.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
