MNRon's avatar
MNRon
Anyone with a lathe?
I have a wonderful Powermatic lathe at home. The only problem with it is that at ~600lbs (plus another 300lbs ballast I've added) it's a little heavy to take along in the RV.
I'm looking at smaller lathes to take along to have some turning fun while we travel. At this point it's probably down to a Nova Comet2 and a Delta midi, at 75lb and 100lb respectively. The Delta appears to be a better lathe, but doesn't really have any 'features' over the Comet. Looking for any comments from others that might have packed something similar in their basement. Will I be sorry to lug 100lbs in and out and should go with the Comet? (If weight wasn't an issue I'd be getting the Jet midi, but at 120lbs I've already ruled that out).
Also if anyone has turned on the Comet I'd appreciate your thoughts about it. Thanks for any feedback.
  • Thanks Dog Trainer, but 75HP is closer to my TV capabilities than the lathe power I expect :) Bet it could make one heck of a bowl or platter though!
  • I am going to be a smart alec here and say that the last lathe I had was 35 feet between centers. We used it to turn steel mill rolls and paper mill rolls. I don't remember what the lathe weighed but some of the rolls we produced were in the 20 ton range. I believe the Lathe was 75HP.
