Acdii's avatar
Acdii
Arctic package and water lines
My trailer has the arctic package which insulates the belly. The only exposed water lines are the two drains, and the tank drain. I have not winterized yet as I need to take one more trip to check out the hitch and some changes made to my truck to see if they corrected a handling issue. I need to do it with a full FWT, so have not drained anything and we are supposed to get a day or two over the weekend of below freezing temps overnight.
If I put pipe insulation on the three exposed pipes, and run the heater on the lowest setting, or have an electric heater to keep it at least 50* inside, will that be enough to prevent any issues> I doubt it will stay cold enough to cause any ice, but better safe than sorry. Hopefully the following weekend will be dry so I can take the test drive and then do the winterizing, and get it prepped to store.
This year went by too fast, and we did not get as many trips in as I would like. :( Mainly due to having to replace my truck earlier in the year and then have handling issues.
  • It won't be an issue, until it is; then it's too late. Your fresh water tank won't be the issue, to much mass. The problem is the pencil lead sized water line fittings that have no mass. So do you feel lucky?
  • Below freezing overnight is not typically a huge deal but yes that little exposed drain valve may freeze.
    I doubt it will break though as many including myself have camped in winter with water and it's not been an issue.
