Mike134
Jun 27, 2021Explorer
JRscooby wrote:
Does nobody remember "snow tires"? Back in the day most people, on most vehicles, ran rear tires that did not match the front for about half the year.
(On my pickups, snow tires in winter, then spring I would name them "Mud Grips")
As for different size F/R. 2 wheel drive, this is not a issue. 4 Wheel drive, can be a problem unless on surfaces you need 4 WD, and tires can slip
X2!! Plus in the early days they always recommended keeping radial tires and bias tires on the same axle, lots of mix and matching back in the old days.
You'll be fine don't listen to the online negative Nellies.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
