- BarneySNomad
swimmer_spe wrote:
myredracer wrote:
A photo of truck & trailer hooked up might help.
How do I post a picture?
How to post a picture on RV.net.
It is as simple as upload picture, copy URl, and paste that URL into your post without making ANY changes - no additions and no deletions. :) - swimmer_speExplorer
How do I post a picture? - myredracerExplorer IIA photo of truck & trailer hooked up might help.
- mkirschNomad II
Grit dog wrote:
Whatever the issue is, a wdh on a sub 3000lb trailer behind a truck like that is not needed, nor will it do anything. Not enough tongue weight to make a difference.
Unless it's some stupid load like a 2000lb concrete block loaded right at the front of the trailer...
It could be simply driving too fast for the terrain. - Grit_dogNavigator IIIWhatever the issue is, a wdh on a sub 3000lb trailer behind a truck like that is not needed, nor will it do anything. Not enough tongue weight to make a difference.
- mkirschNomad II
swimmer_spe wrote:
time2roll wrote:
afaik 500+ tongue or 5,000+ trailer weight should have WDH.
Trailer is half that weight.
Then you don't need a WDH unless you have a very strange setup where the trailer has something like a 50% tongue weight. - swimmer_speExplorer
Trailer is half that weight. - afaik 500+ tongue or 5,000+ trailer weight should have WDH.
- blt2skiModeratorBounce could STILL be shocks, depending upon the brand and type you had installed. Another bounce, could be sidewall flex. Springs on 15 series rigs are softer than a 25 or 35 series too! SHorter Wheel base rigs will bounce more than those with longer wheel bases too! You may have some or all of these issues!
Another as I am typing. If the trailer is loaded a bit lite on the hitch, it could aggravate the bounce by trying to lift the hitch as it bounces, especially Single axel trailer vs dual axels.
I've found with my SW 35 series rigs, if I have more than 400 lbs removed from the FA, using a WD is very much needed etc. But a 6000 lb trailer with around 700 lbs of HW< usually only removes 60-100 lbs off the front. My 1500 lb HW equipment trailer does put an 8500 GRAWR rig at 300 off the front, and a typical 6400 lbs RA at or about 400 lbs. A WD was really nice on this rig.
My TT was not needed with said 60-100 lbs off the front. BUT< with that said.....a basic WD will help reduce the side wind, side to side rocking of the trailer. A dual cam helped even more! I would swag a hensley or equal even more so. - swimmer_speExplorer
BarneyS wrote:
Campfire Time wrote:
Bobbo wrote:
Measure the distance from the ground to the top point of the front wheel well, both before and after hooking up the trailer. If there is more than 1/2 inch difference, you need WD.
X2! Rear squat is not an indicator that a WDH is needed.
Even a fairly light trailer with a 150/1500 series truck can take enough weigh off the front to require a WDH.
He did not mention nor was he talking about rear squat. He was talking about the RISE of the front fender which would indicate weight being removed from the front axle.
Barney
Actually, I am not paying attention to what the front is doing. The back of the truck and the front of the trailer are bouncing madly. Thought it was shocks, changed them, and it still does it.
Sounds more and more like I may not *need* WD, but it would resolve the problem.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
