full_moseyExplorerJul 23, 2013At what psi can I travel 65-75mph? This Maxxis pdf has the same table. Using the table(s) above, my ST175/80R13 with 1060lbs load could run at a minimum 35psi with ~4% reserve capacity. Is there a +10lbs rule? I run with +1...Show More
FastEagleExplorerJul 26, 2013Here are three references with clearly defined definitions used by the regulating body. Ref #1Ref #2Ref #3FastEagle
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
Related ContentTravel TrailerMy Travel Trailer Fell DownTravel trailer front lights stay onRV Travel Insurance?Water Pump Failure Traveling To The Eclipse
