Francesca_Knowl
Jul 26, 2013Explorer
kedanie wrote:
In your quoted PSB, it is clearly stated, "Do not exceed the maximum pressure for the wheel".
If your "wheel" includes a 13" LR-C tire, it carries a maximum of 50psi. Now then, if your "wheel" includes a 15" LR-D tire it carries a maximum of 65psi.
Which do you have 13" or 15" LR-C or LR-D?
Keith
The O.P.'s opening post indicates his are ST175/80R13- I thnk LR-C is as high as those go.
That said:
The above post may clear up a point of confusion in my mind, that being the meaning/use of the word "wheel". I've been thinking of that word as interchangeable with "rim"....but if "wheel" is more correctly defined as a combination of both tire and rim, the lowest rated component would govern maximum capacity.
Is that correct?
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
