Francesca_Knowl
Jul 26, 2013Explorer
full_mosey wrote:
The sticking point for me is trying to understand that
" PSI is obtained from the inflation/load chart for the tire and using that pressure plus 10 PSI"
is equal to
"cold inflation pressure by 10 psi (69 kPa) above
the recommended pressure for the rated maximum load".
Goodyear says the latter.
HTH;
John
I just reread the sentence in the bulletin that uses the words "rated maximum load". Seems a bit obscure...is it possible they're talking about the "rated maximum load" of the axle the wheel's mounted on?
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
