JJBIRISH
Jul 27, 2013Explorer
full_mosey wrote:CapriRacer wrote:
Just to muddy the waters some more:
Has anyone actrually looked at the tire to see what it says? I'll bet it says " Max Load XXXX at YY pressure". That does NOT indicate a maximum inflation pressure.
My current tire is Milestar; original equipment.
I reads "Maximum load 1360lbs at 50 psi cold".
We move one step closer to my 60psi interpretation of the 'industry standard' for traveling between 66 and 75mph. :)
HTH;
John
Tireco Inc
(310) 767-7990
500 W 190th St # 6, Gardena, CA 90248
Contact them, they are the importer of you tires… they should be the ones that can officially give you what you keep asking of us…
In the end, You will believe what you want and discard the rest anyway,, and you will find a reason for justifying your decision… so just do it…
Looking for advice before your next adventure? Look no further.25,188 PostsLatest Activity: Mar 24, 2026
