full_mosey
Jul 27, 2013Explorer
JJBIRISH wrote:
In the end, You will believe what you want and discard the rest anyway,, and you will find a reason for justifying your decision… so just do it…
Actually, that describes you.
I wrote:
The sticking point for me is trying to understand that
" PSI is obtained from the inflation/load chart for the tire and using that pressure plus 10 PSI"
is equal to
"cold inflation pressure by 10 psi (69 kPa) above
the recommended pressure for the rated maximum load".
Goodyear says the latter.
HTH;
John
I asked, but you do not explain what I read wrong. You only answer what you want to answer. C'mon, exactly what phrase in the Goodyear reply did I misread.
So far we have had a civics, poli-sci, corporate conspiracy theory and a history lesson.
The reply says what it says until someone can explain otherwise.
HTH;
John
Looking for advice before your next adventure? Look no further.25,188 PostsLatest Activity: Mar 24, 2026
