Well, in my experience with this unit, you guys are all correct and all wrong!!
First you are absolutely correct about the BIMBO. She told me the same thing about the temperature being to warm in the room. Good heavens, are people really that stupid? Well, maybe so.
I originally installed and tested its operation in both heating and cooling in early September. But didn't really use it other than to test it. Mine do operate though. I installed two of them (Atwood 15033 black version of the 15028) in place of one Coleman 13.5K and a Coleman 11K BTU a/c. I have an Intellitec system that compounds the issue. I rewired everything in order to get it to work and the first time out my daughter used it and suffered by setting the system to 60 degrees and never called me to help them get it running even though I had provided them with a step-by-step on how to use it.
The second time out, I was there. The symptoms are that the air conditioners operate like a champ, but the heat pump fans turn on, run for 5 seconds, turn off, wait thirty seconds, turn fan on, turn off after 5 seconds and then immediately turn on the heat pump compressor - kicking out huge amounts of very warm air. But then it goes back to the same cycling BS again. All night long the same constant cycling - enough to drive someone crazy.
The second night, the temperature dipped a little colder and the unit refused to come on at first - ran the furnace instead. Not realizing what was happening, I shut it off and set the temperature to 60 degrees and operated the air conditioner for a minute or so. (I had apparently waited until it got too cold to turn the heat pump on.) As soon as I discovered that the heat pump could be made to function doing that, I ran each a/c until it was definitely cooling and for about 30 seconds to one minute, then switched it to heat pump using the setting of whatever the room temperature was plus 1 degree. I was able to increase the temperature slowly, moving it up to the 'room temperature' reading.
Still, every once-in-awhile, the unit that operates the furnace would kick in. So I would start over. That night after I finally got things set up, the units would operate continuously as they should - that is, the thermostat called for heat, the fan started on low, the compressor started (the fan kept running on low) soon the fan ran faster (when the heat pump was outputting heat) and as the temperature increased, the fan speed increased. When the temperature limit was reached, the compressor shut off, the fan continues to run until a timeout is reached. That, oddly enough, is how it is intended to operate, I think.
The furnace is set to operate from only the front unit. When the other unit goes into reverse mode to clear the coils, the furnace does not run so it never comes out of that function. So the second night, the a/c unit w/o the furnace did not run much. It shut off leaving the furnace and the second heat pump to heat the coach. But at least that incessant 5 second run, 30 sec off, 5 sec run, 30 sec off of the fan did not happen.
However, the next night it was warmer and what little heat was needed, the heat pumps provided, but with that 5-, 30-sec cycling BS.
If your system is set up correctly, the furnace is designed to be backup for the heat pump and should not be set to 'Furnace', ie, do not switch the furnace button on the thermostat to on. That expects the furnace to operate as a normal furnace and bypasses the sensors. Mine just turned on and heated the place up to 80-90 degrees.
I think that I am going to modify mine so that the second thermostat also operates the furnace (I only have one furnace) somehow. Right now, the furnace feature is disabled on the rear heat pump, so the heat pump stops and cannot start again because of their idiotic coding, I suspect. If I tell it to go into furnace mode automatically, it should work like the other one and start up again once it stops to defrost itself. In fact, I might not have to do anything to the unit except change the jumpers to allow furnace even though it doesn't actually operate the furnace.
Update: the jumpers were already set to S2 2-3 jumpered which means that it is the same as the other that has the furnace. All I did was wire the Atwood relay in series with the other shutoffs. The power comes to the furnace as 12 vdc red wire, goes through some fuses and then out on a blue wire to the a/c through the relays and back to the furnace on another blue wire through the butterfly switch to ground.
I found that the temperature on the control set at 75 got the walls to 68 about halfway up the wall, but so did one set at 75 and the other at 72.
My setup is a ducted system in a 2004 Fleetwood Flair 33R. It uses 30 amps and I have modified it so that I can operate as 50 amp or 30 amp. The Intellitec unit controls the shedding of the a/cs when the load on the 30 amp side gets too high. I figured out a way to keep using that feature by using an additional 30 amp ATS (total of three) and two Solid State Relays (SSR) to allow the Intellitec system to intercept the unit to be 'shed'. Both units can be 'shed' when using 30 amps only. One is shed when using the genset or 50 amp service, but it took a third 30 amp Automatic Transfer Switch to do it (cheaper by a long shot than one 50 amp ATS).
The thermostat for the bedroom rear unit is located in the bedroom proper. The front unit's thermostat is on the wall in the center of the coach. Each of the units pushes air into center of the coach and to the nearest end - ie, rear units feeds the bedroom and center of the coach, while the front unit feeds the center of the coach and the front of the coach. There are two separate ducts to provide this capability and it nets out fairly evenly across the coach.
I am very impressed by the Atwood AirCommander. It is a reworked version of the Cormorand built by AirCommander in Australia. The Dometic company apparently is attempting to get rid of a very good product by making it look bad.
It is very well designed and except for their poor engineering of the control board, has pretty good state-of-the-art features. It runs on less current to produce the equivalent of 18K btu per hour and the heat pump puts out like gang busters. It does it with less current than my smaller Coleman units and cost a bunch less. Plus it has a good looking digital thermostat and may be used ducted or ductless, not to mention the much superior filter design.
The main objection that people mentioned was that it uses reverse air flow so although that is better for driving along, it is not so good for situations where the outside unit has to be cleaned. The Coleman requires climbing onto the roof-top to clear the crud off the coils where the Atwood requires the cover and the plenum to be removed to get at the coils. This is not a big issue for me, but if it is, I would rather use a fine mesh screen on the low speed input side rather than take it apart a lot.
