zackyboy3rs's avatar
zackyboy3rs
Atwood water heater breaker tripping
Today breaker has tripped twice. Just now it stayed on for 2-3hours and then tripped. 50amp. Ac not running. Nothing in camper running expect lights. Could it be heating element? Thermostat? Can I just run it off of LP?
  • Well it has not tripped but once. I thought I heard it trip but it did not. So far all good.
    2015 Atwood combo electric/gas uses the SAME set of t-stats for electric & propane......same circuit board-----same DC controls
    Only thing separate is the 120V AC for electric element
    If that individual CB for water heater is tripping then problem is with the electric element circuit
    Either the AC wiring at the DC Relay, the wiring on the element or the element itself.
    All of that is located in same place.....under the protective cover on backside of WH Tank (inside the RV)
    Access can be easy Or really tight/difficult depending on the RV MFG and where WH is installed.
    Propane can be used as heating source ----it just uses DC & Propane to function
    Testing of element: 120V AC Power ON (CAUTION)
    Use voltmeter and check that you have 120V AC between HOT (Black Wire) and NEUTRAL (White wire) on the element terminals
    (Electric Switch ON and water temp below 110*F to controls are calling for HEAT)
    Testing of element: NO AC POWER
    Check continuity between Black Wire and White Wire Terminals on element
    NO CONTINUITY------ELEMENT is BAD
    Check continuity between White Wire Terminal and element flange
    CONTINUITY-ELEMENT is SHORTED
  • Pretty sure it's tripping for a reason. Most likely a bad heater element.
    Best to shut off the electric element in the water heater and just use gas until you can get 'Round2it'. BTW, I only used gas to heat the water 5 to 10 minutes before needing it. Shut off after. Save on gas that way.
  • Is that a GFI breaker you are referring to? If so, a bad heating element can trip it.
  • Check the ohms on the heating element. My guess its going bad.
