ib516
Aug 23, 2013Explorer II
Mine had it when I first got the truck, it was repaired under warranty.
Date: May 24, 2007
Models: 2004 - 2007 (D1/DH/DR) Ram Truck (2500/3500)
Overview:
This bulletin involves the replacement of the governor pressure solenoid valve in the transmission valve body.
Symptom/Condition:
The customer may experience a 1-2 shift transmission hunt during light throttle application. This condition may be due to a governor pressure solenoid valve.
Diagnosis:
If the customer experiences the above condition perform the Repair Procedure.
Parts Required:
Qty. Part No. Description
1 04617210 Valve, Governor Pressure Solenoid
4 05013457AA ATF+4 Automatic Transmission Fluid
AR 02464324AC Gasket, Transmission Oil Pon (Note: Original pan gasket is reusable and should not require replacement).
Repair Procedure:
1. Raise the vehicle on a suitable lift. Turn the ignition switch to the "OFF" position. Remove the ignition key from the ignition switch.
2. Remove the transmission fluid (oil) pan and pan gasket. Clean and save the pan gasket for later use during reassembly.
3. Disengage the wire connector to the governor pressure solenoid valve (Fig. 1).
4. Remove the screws used to secure the governor pressure solenoid valve retainer to the transmission valve body.
5. Remove the old governor pressure solenoid valve from the transmission valve body.
6. Clean the transmission housing and oil pan gasket surfaces.
7. Lubricate the o-rings on the new governor pressure solenoid valve.
8. Align the governor pressure solenoid valve to the bore in the valve body.
9. Install the governor pressure solenoid valve to the valve body.
10. Install the governor pressure solenoid valve retainer and attaching screws to the valve body.
11. Connect the wire connector to the governor pressure solenoid valve.
12. Install the transmission fluid (oil) pan and pan gasket (saved earlier) to the transmission. Tighten attaching bolts to 13.6 Nm (125 in. lbs.).
Fig. 1 Governor Solenoid And Pressure Sensor
1 - GOVERNOR PRESSURE SENSOR
2 - GOVERNOR PRESSURE SOLENOID VALVE
3 - ELECTRONIC GOVERNOR
13. Lower vehicle.
14. Add automatic transmission fluid to the transmission.
15. Verify correct transmission fluid level.
Policy: Reimbursable within the provisions of the warranty.
Failure Code:
ZZ Service Action
Musky50 wrote:
Could someone explain ''Shuttle Shift'' I just bought a 07 Ram , Cummins and haven't towed with it yet. Just trying to learn something here.
Date: May 24, 2007
Overview:
Symptom/Condition:
Diagnosis:
Parts Required:
Repair Procedure:
13. Lower vehicle.
Failure Code:
ZZ Service Action
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
