carringb
Apr 17, 2014Explorer
PUCampin wrote:
Bryan, I am curious, do you know what gears the 6R75 locks up in? I know when I am going slow like through a parking lot, it FEELS like it is locked. It will "chuck" some with throttle tip in and out like when driving around my car in 1st. Same if I am driving in 1st or 2nd going up a hill and feather the throttle, tip in and out is not as smooth as I would think if the converter was unlocked. If in 2nd or 1st and I let off the throttle, the tach drops in a linear manner with the speedometer until I am almost stopped where it will pop up a little like the converter is unlocking.
Whatever it does, I really like how they drive. I just wish I had the full manual control like the later ones, I would love to lock out 6th but NOT 5th for towing on the flat.
I believe it does. I think all of the Ford with drive-by-wire lockup in all gears. The "pop" you notice during deceleration is probably the fuel injectors firing again. Normally during coasting your T/C is locked and the engine is completely de-fueled until it drops below a certain RPM.
If you get a 5-star Tuner, you can have a 6th-gear lockout enabled for towing. I know some guys like this feature for the 5R110 behind the V10, because it also does not have an overdrive lockout.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
