Dave_H_M
Aug 30, 2018Explorer II
TimnJo wrote:
I can't find a link to the relevant legislation so you can take this as hearsay - my diesel mechanic who installed my auxiliary tank outlined his take on the rules:
You can have an auxiliary tank for either fuel type but the gasoline type cannot be plumbed in to the main filler tube with a roll-over valve the way you are allowed with diesel.
I think your installer is correct. When i was researching several years ago i recall that gas has to be pumped out of the dip tube in the tank. When i first installed mine i had trouble with the gas siphoning through the pump. i then added a veton normally closed shut off valve between the pump and the main tank and all has been well. When i turn the pump on the shut off is also opened and she pumps away.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
