rk911
Dec 30, 2017Explorer
presumng your tanks are heated when using the LP furnace.
plan a:
- fill your fresh tank, drain, disconnect and store your hose. live off of the tank.
- place a lit 60-watt incandescent bulb in proximity to your water pump.
plan b:
- wrap your fresh hose, the connection and exposed pipe in heat tape.
also...dump your gray and black tanks, drain, disconnect and store your hoses. we also open the cabinet doors under sinks which allows warm air to circulate there. close slide out rooms not necessary for use especially at night.
plan a:
plan b:
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
