mobeewan
Dec 31, 2017Explorer
Old-Biscuit wrote:
YEP.........
Use the fresh water tank & pump
Refill tank during warmer daytime temps and then drain/stow hose until refill needed
This is what I usually do.
With taking one shower every other day I could go 9 days between FW tank refills (4 showers, flushing toilet and washing hands). I also filled 2 - 7 gallon Reliance (Walmart) containers and brought them inside the trailer when outside temps were not going to get above 30 degrees for several days. My plan was to drop the pump winterizing tube inside a 7 gallon container and turn the winterizing valve if needed. Had to do it once when the pick up tube from the fresh water tank iced up for about a day and then temps went back up so I could top off the tank. I hate the jack knife sofa and plan on adding an auxiliary 30 to 40 gallon FW tank where the jack knife sofa is when I remove it and build a bench seat in it's place.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
