crcr
Apr 26, 2017Explorer
fj12ryder wrote:
Have you checked behind the gutter where it's pulled away to see if there are screws back there that have pulled loose? Did you have gutter installed? If so perhaps you could take it back to the installers and have the problem rectified.
Also you might check for any water intrusion into that area that has softened any wood that the screws attach to.
Thanks, no haven't yet looked behind the gutter -- not going to be easy to see under there, but I'll give it a try.
No, I didn't have the gutter installed. I bought the TT when it was 3 years old, and I'm almost 100% sure that the gutter is factory equipment.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
