crcr
Apr 26, 2017Explorer
There should be minimal pull when retracted vs. when extended and the spring is under more tension. If the two large lag bolts that hold the top awning support showed any rust ...
Thanks. That may be what "should" be, but the fact is that there IS more pull when retracted, and more on one end than the other. I suspect it has something to do with how the awning is mounted or rolled up, or the spring tension setting on the roll, or??? In any event, I'm not going to try unrolling and re-rolling the awning, changing the tension, etc. Once repaired, I just will stop retracting it before an excess of tension is applied on that end.
I live in a dry desert -- I find no rust whatsoever on this RV.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
