taigarazz's avatar
taigarazz
Awning Won't Roll Down
so, no previous problems with the manual awning. Then, this week end, it won't roll down. The fabric won't come out at all. The lever is in the roll out position, but no budge. i got up on a ladder and looked, but no visible issue.
Any ideas?
Linda
  • Will the lever operate and feel like it has a snap over center when it does… It is a simple cam and cog design… there have been post where the lever turned on the shaft…
  • Vet Man wrote:
    Try raising up on it before rolling out.
    Ours has this problem occasionally and lifting the awning arm will allow it to come loose. It's hard to do with one person...lifting and pulling at the same time.
  • When we had a manual awning sometimes the awning would lock up because I didn't push up (raise) on the awning rail before I tried to roll it out.
    When you roll up a manual awning you must push up to lock it. Then when you want to roll it out you must unlock it (push up on the rail).
    Here's a video illustrating the whole procedure.
    Click here: Awning operation
    Happy trails,
  • Awning arms unlocked. I yanked really hard. I can't seem to find any exposed mechanism ..
    Linda
  • HappyKayakers wrote:
    Awning arms unlocked?
    Make sure you unlocked the arms and give it a good yank. One side of mine does not like to release without it.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
