Veebyes
Jul 26, 2015Explorer II
Axle install
We met up with a nasty highway dip last year & the dip won. Unaware of the damage till tire wear told the tale. Bought a new axle & now need to get it installed. I do most of my own work but this i...
allen8106 wrote:RCMAN46 wrote:
Make sure you get a good welder that has welded trailer axles before.
The trailer axle tube is almost paper thin and is a challenge to weld.
You don`t weld on the axle. It should bolt to the leaf springs. The leaf springs bolt to brackets welded to the frame.
