Vin plate says GAWR front 5200. GAWR rear 5200. I'm assuming that means I have 5200 pound axles? Or would they just be referred to as 5000 pound axles?
No because you need to subtract the tongue weight. When hitched up the tongue weight is not on the axles.
7540lbs minus 540lbs for the tongue weight = 7000lbs. 7000lbs divide by 2 equals 3500lbs. More important is the CCC of the trailer. Your has 2945lbs. Even loading in 1/2 that you should still have enough reserve.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
