Terryallan
Jul 21, 2015Explorer II
westernrvparkowner wrote:
I am with the others, driver's side is probably preferable, but circumstances often make the passenger side preferable. Things like curling around a tree, someone parked along the road, the angle of the site and probably a hundred other considerations help make the decision.
One thing that is almost constant, and not understood by many people is you need to get as close to the site as possible before you swing away to begin backing up. This is the exact opposite of what you should do to pull into a site where you should swing out as far away from the site as possible before swinging in.
The other old saw I often quote is: You need to drive more like a truck driver and less like an RV'er. Truckers drive fast on the interstate and back up slowly. RV'ers tend to do the opposite .
You are correct
The reason you swing in close to the site, and than swing away. Is to line up the rear of the TT with the "hole". You swing in to get more room to swing out. You pull past, and away from the site until the trailer best lines up with the hole. Then you turn the TV so that when you start back. It will already be pushing the trailer in the direction you want to go. IF there is room. That works great. IF you get the trailer lined up with the hole. Half the battle is over.
Biggest problem. "Most" CGs don't have the room needed to make the swing in, and then the swing out work properly.
And of course when pulling into a pull thru. You want to be as far away as possible, and almost pass the site to give room for the trailer to follow in. Also has the same room problem.
My Uncle taught me that some 43 years ago. Part of my job at the boat shop was to back the finished boats into the ware house, and then into holding spots along the side. Like the 90% parking spaces in a lot. When I got to use the tractor it was easy, as I could straddle the steering wheel, and see what I was doing better.
and in truth. I can put my TT in a site where I want it better backing, than I can pulling in.
