memilanuk's avatar
memilanuk
Explorer II
Jul 05, 2019
Bad taste/smell to fresh water
Recently started noticing a nasty taste/smell to our fresh water system. Initially I attributed it to the DW using a 'new' garden hose to reach the one spigot on the house that comes off the domestic water system (vs. the canal/irrigation water that supplies all the other outdoor spigots). The water pretty much smelled/tasted like the black rubber on the inside of that hose...
We drained, flushed, refilled (from a completely different water source, at a different location, using our usual white 'potable' water hose) and... it still smelled/tasted bad. Maybe not quite as bad as before, but close.
Went and got some de-winterizing solution, and followed the directions - basically drain the system, fill the tank, add the solution, run thru the lines (including water heater), then drain and flush with plain water two more times. That said, the water source *has* been from the same spigot on the house as before, albeit with proper white 'potable' water hoses.
The water *still* tastes/smells kinda funky. I have somewhat of a hard time thinking that using that one hose, one time, would have contaminated the *entire* system that badly.
Any other ideas/suggestions? We'd discussed adding a small amount of chlorine (bleach) to the tank to try and clean things a bit; I've also seen some discussion elsewhere about build-ups in the water heater causing grief and needing flushed with vinegar solution to remove. Given the fairly sudden onset in this particular instance, I have my doubts about that being the case here, but I'm open to ideas.
Thanks,
Monte
  • Of course you should sanitize the ENTIRE system with bleach. There are many videos and helpful sites online to help you. Also, drain and flush the water heater.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
