cahillprc2's avatar
cahillprc2
Bad Water Smell
If this has been asked before I couldn't find it. We bought a new TT from a dealer a little over a year ago. Unfortunately due to the deaths of my son and wife, we never got to use it until about a month ago. Unfortunately, it appears that the dealer DID NOT drain the water system including the water heater or fresh water tank after pre-delivery testing and demo. So water sat over last summer, winter and this spring UGH ! Clearly we need to sanitize! But I've read where bleach can be bad for the water pump and other seals, as well as the W.H.
I also read somewhere that you could use Hydrogen Peroxide in place of bleach. So I poured 2 16 oz bottles into the tank and ran it through all the pipes and water heater. a day or two later when I went to drain it all out, there was a foul sour smell coming from the water. I completely drained everything including the WH, refilled the 35 gal water tank adding a 1/2 cup bleach, and changed the bypass valves so bleach water would not go to WH. Then ran all fixtures H&C lines. at first the foul smell was still coming out but quickly went away. However I could not detect a bleach smell. Nevertheless I let it all sit overnight and in the morning, added another 1/2 cup bleach and ran all faucets again. If this does not take care of the problem, What else can I try??
Thanks in advance, and I apologize for the long question.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
