  • Having a sealed underbelly a winch type system would be a little more complex. I did put on a winch system on my last Rig but it was all open on the bottom and much easier to access frame rails and bracing. The front A frame is a option but it would add 50+ pounds right on the tongue though...
    I was curious if this BAL system is sturdy or does it bounce or flex with a 50lb tire on it....
  • Go to an auto salvage yard and look for a pick-up truck that has the spare mounted underneath the bed, some of these spare tire carriers raise and lower the spare tire using a cable system. A bit of fabrication and you have a simple solution for mounting the spare under the front A-frame portion of the trailer.
  • Just one comment.
    It looks like you will lose a good amount of ground clearance at the rear where you would need it most for exiting roadways or drives.
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
