JRscooby
Jul 14, 2023Explorer II
I can't address much, but will point out 250 ft lbs is only 50 pounds of pull at the end of a 5 foot long bar. If you rotate the ball mount in receiver, you can position the nut so you are pushing down when need max torque. If you put block or jack under hitch you don't waste motion compressing suspension before nut turns.
BTW, to break loose (finale tighten) hold bolt/turn nut. Don't add friction of bolt in parts.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
