MitchF150
Jul 14, 2023Nomad
For the high torque nuts, you will need to get a socket for that size. Likely around 1-1/8" and 1/2" drive. You will need a long breaker bar if you don't have a long handle torque wrench.
You won't need new nuts/bolts. Once you get that far, adjust accordingly.
If no torque wrench, just use your breaker bar and maybe even a 'cheater bar' on the end of that and tighten it up as much as you can without breaking the bar.. :)
Good luck! Mitch
Good luck! Mitch
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
