JRscooby
Jul 15, 2023Explorer II
blt2ski wrote:
Scooby,
Yes correct on the hitch weight changing. Level might be 100 lb, an inch high 98, 2' 95 lbs. Going down, an equal increase IE to 102, 105 lbs. Enough to stop fishtail sway? That would depend on the how high at the start, vs getting to level or slightly down as I prefer. Along with the actual change in weight that occurs during this swing.
Marty
Like I said, it depends on where weight is in the trailer. If something heavy is high over the axles can make more change. Your numbers might be right, for your trailer. I know if I use my flat ball mount instead of the drop my half ton squats less. (Jackknife a little to slide cooler off back porch to tailgate. First gas stop, switch because drop/level trailer feels better)
And the OP mentioned air suspension. Will the slight change in weight change pressure in bags, effect how it handles?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
