32vld's avatar
32vld
Ball Loosened, Use Loctite?
From time to time my son or I have to tow bar
his 1946 Chevrolet 2 ton rack truck. He uses it
for his food catering business.
Being it is old it breaks down once a year. So
when booked to do a party he has to get his truck
there so it is towed with a Chevy Suburban.
Well the truck just had to have the head R&R so the
truck had to be towed a few times. This time I bought
a new draw bar and 2" ball to get the tow bar level
when towing his old truck.
The problem is that the ball came loose after a few
tows. Last year we had to tow his truck for many weeks
because his engine was at the machine shop getting
rebuilt and we never had any problems using another
draw bar and ball.
I did not have a 1.5 wrench so I went to my neighbors
house, retired mechanic. He tightened down the nut
with a long combination wrench. Then doubled up the
wrench and gave it another tug.
Any ideas why it loosened?
He used anti seize grease when tightening the ball
to the draw bar. He said incase you ever have to take
it apart. I never did that before.
Could that of caused the ball to loosen?
Is it a good idea to clean off all the threads and
apply Loctite?
Thanks for your help.
Here is a link to my son's website so you can see his
truck:
http://www.pizzarita.org/
  • wnjj wrote:
    Yes, it does matter.
    Yep. And one of the easiest ways to understand why is to consider what happens with a torque screwdriver, where you twist directly over where the torque is measured. Put a crowfoot type extension on a screwdriver, and you'll never apply any torque to the fastener because you only end up trying to push it sideways, not rotate it. (You can apply torque to the fastener by pushing the screwdriver sideways, but that isn't measured as torque and if you do that, you can also torque the fastener while applying no torque to the screwdriver). Similar thing with wrenches, although less intuitive - the effective torque depends on how far from the measurement force is applied.
  • Are people so intent on proving themselves right that they will bicker over 6 pages of thread over <1% difference?
    We're tightening a hitch ball here fellas, not machining parts for the space shuttle.
    If the spec is 250 ft-lbs, it's not going to snap off at 251 ft-lbs, and it's not going to fall apart at 249 ft-lbs. Heck it's not going to snap off at 260 ft-lbs or fall apart at 240 ft-lbs. Everything has tolerances, except maybe space shuttle parts.
    A 200lb guy putting all his weight on a 15" lever arm will exert 250 ft-lbs of torque. Stand on it until it stops turning, and maybe give it a little bounce-bounce for good measure. It's tight enough, and if you take it to the professional and have them put their torque wrench on it, I bet it will be within 5%
  • wnjj's avatar
    wnjj
    Explorer II
    To be fair, the thread got a bit off topic so we weren't "bickering" about a ball hitch. We weren't even bickering as much as discussing. I, for one, welcome discussion as I wouldn't have given the proper thought as to what does or doesn't affect a torque wrench were it not for this thread.
    The reality is most people don't have access to a 200+ ft-lb torque wrench so the accuracy is probably a moot point. The past few I've installed either had the included plastic crush washer, were assembled on a drawbar already or were just bolting onto my quad where the torque wasn't important.
  • It's just this, "If it's not torqued to EXACTLY X foot pounds, you're going to die, your wife is going to die, your kids are going to die, your mother is going to die, your dog is going to die, everyone within a 3-mile radius of your vehicle is going to die," attitude that seems to prevail with this subject.
    The past few I've installed, I've used the "XXX-pound guy standing on Y-inch long wrench" method and not one of them has come loose either.
    Yes if the OP follows this.... no loctite needed.
    Easy simple
  • Lock washer or not, the ball has to be properly torqued, so as to stretch the shaft to the point where the nut cannot rotate on the threads with less torque applied. The anti-seize was a mistake, torque specifications are almost always for dry threads, adjustments for lube are problematic, but you probably didn't torque it properly anyway.
    Use Loctite only if OEM recommended, with the expectation that you will never want to take it apart. Blue Loctite is more easily overcome, but it will take more torque to get it apart than it took to put it together. Consider red Loctite to be almost as permanent as a weld.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
