DE88ROX's avatar
DE88ROX
Barker tongue jack issue
Last Fall, when hooking up my trailer to bring home for a weekend trip, my Barker VIP 3500 tongue jack stopped working.
I called barker and they sent out a new switch.
Well, this weekend I brought the trailer home to de-winterise and get it ready for next weekend. I replaced the switch. As I pulled the wires off the old switch, i put them on the new one. making sure every wire was in its proper placement.
Jack STILL wont work!
Ive checked all fuses and they're all good. The light is working, so that tells me I have power going to the unit.
I went to Barkers web site and in the 'contact us' section, I basically told them the same thing. see what they say I guess.
In the mean time, any of you handy man DIY Gurus have any thoughts on what may be the issue?
Thanks in advance!
  • Assuming your batteries are charged......If Barker doesn't get you going quickly, the $100 jacks from China work well. Good luck.
  • gaymeadowsman wrote:
    You may have just enough ground connection to operate the light but not the jack. That happened to me and my Barker. I removed the jack and sanded the rust off around the mounting holes on BOTH the jack and trailer tongue. then placed stainless steel washers with the "teeth" between the the jack and tongue tightened the bolts back down. the jack worked perfect.
    Well, I hooked up the trailer and removed the jack. Took my Dremel tool and ground the frame of the trailer as well as the underside of the bolt flange on the jack right down to bare metal. Replaced the washer with a brand new stainless steel locking washer (with the teeth)
    STILL wont work. ive exhausted all my known options.
    This is the start of my 3rd season with this jack. Needless to say, im really disappointed in its performance thus far.
    On the positive side, at least i can still use it manually and the its geared different than the OEM hand crank that came with the trailer, so its still a tad faster.
    Buy American! smh
  • I too had problems with an inadequate ground ... paint and corrosion interfere
    I'll give that a shot. thanks!
  • You may have just enough ground connection to operate the light but not the jack. That happened to me and my Barker. I removed the jack and sanded the rust off around the mounting holes on BOTH the jack and trailer tongue. then placed stainless steel washers with the "teeth" between the the jack and tongue tightened the bolts back down. the jack worked perfect.
  • Chuck_thehammer wrote:
    stuck motor.
    stuck/rusted bearing in gear box.
    bad connection at motor brushes..
    bug nest inside of motor.
    to name a few.
    When it first happened, I tore into it to make sure all of the gears were in good shape. The unit was very clean and dry and very well greased. I had a custom waterproof cover made by a friend, to keep it dry.
    Very frustrating.
    I live in Michigan, (an hour from barker actually) so I bought a Made In The USA/Michigan product and it failed me after 3 seasons. :M
  • stuck motor.
    to name a few.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 09, 2025
