genekiwi
Jul 20, 2013Explorer
Bars won't easily release
It is a Reese WDH with the dual cam sway
To unhook, I raise the tongue up until I can safely release the snap up bracket. When I drop the bar down, it does not separate from the cam arm. It seems to be stuck.
On my other trucks, when I took the tension off, the bar and arm would separate on their own.
I did not set this up myself, had a pro do it and also took it to an rv dealer who said the setup was good.
I am on the 4th link, front of the truck is at it's original height, rear is down about 1 1/4 inches and is about the same as the front, trailer is 23 1/2 inches in the rear and 23 1/4 inches in the front.
The chain was originally set by the pro on the 3rd link but the front was up so I moved it to the 4th which seemed to improve the setup.
Any ideas as to why they stick together or how I can avoid this.
Thanks for any help.
