RVMike's avatar
RVMike
Base plate installation
Finished my base plate install on my new 2016 Nisan Frontier. Went as advertised except for drilling the bumper. Roadmaster claims 2.5 hrs to install but drilling the two holes in the bumper took 2 hrs. What ever metal Nissan uses is tough. Broke the first new bit and 1/2 hour to do the next, Besides that a very straight forward install. Know have to find a local trip to try it out. Bought a Falcon 2 tow bar
  • j-d- The new kit is 344-1b. Uses holes already in frame. Only hole to drill was the bumper. The v6 with the 6 speed manual is surprising.
  • j-d's avatar
    j-d
    Explorer II
    2016 Frontier uses the same Roadmaster kit as our 2009. I remember drilling the frame, not the (so-called) Bumper. I know the thin "high strength" steel used in unit body/frames is a bear to drill, sounds like you got into some of that. It isn't too bad if you have:
    1. Powerful LOW-RPM Drill
    2. An excellent Drill Bit (No Harbor Fright here!)
    3. A Lubricant
    I remember drilling the threads out of two large weld nuts in the bumper area and using 1/2" bolts with nuts. Also drilling crosswise through the frame.
    Was installing 344-1A. What did you use?
    You'll love the truck! Smooth, quiet ride, still a tough little truck. Yours oughta be fast. Our 2.5L 4-cyl, not so much.
  • My Cadillac was easy except for drilling into the frame. I went and purchased titanium bits for hard steel and they cut thru it like butter. It made a world of difference than what I first tried.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
