CaLBaR
Jan 13, 2015Explorer II
jplante4 wrote:kyonu wrote:
Thanks everyone for your quick responses! I will definitely check the AAV under the bathroom sink.
The smell only occurs in this space. It's worse with the lid open, and we typically will not smell it unless we open the door (as shown in the pic). If it's NOT the AAV, how should I go about cleaning the vent pipe?
Thanks again!
Climb up on the roof with a running water hose and stick it down the vent. If it's plugged, it will fill up and overflow. Jam the hose in as far as it will go, jiggle is around and when the vent drains you're done.
Yeah, you can do it with a snake, but this is much more fun. And you already have a hose, probably not a snake.
I had the exact same problem with the smell and did the hose water trick and voila no more stink. This is easy to do and if the smell is still there look further.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
