TucsonJim
Oct 29, 2013Explorer II
beemerphile1 wrote:
It charges if the tow vehicle is wired to do so.
Use your volt meter and measure your seven pin connector at the back of your TV with the trailer plug disconnected. You should have approximately 13.5VDC when measuring from pin 1 (Ground) to Pin 4 (12v). If you have no voltage between pin 1 and pin 4, let us know the type of TV and we'll help you trouble shoot it.
Jim
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
