jffnkrnExplorerApr 30, 2015Battery Amp HourDoes the amp hour rating double when two twelve volt batteries are used? I understand that they need to be both new so they don't go down to the lowest setting. thanks
RoyBExplorer IIIApr 30, 2015These are the two typical ways to get 12VDC from batteries in our RV Trailers.Using two each 6VDC Batteries in SERIES...Using two each 12VDC Batteries in PARALLEL...NOTE how the AH's is affected with the SERIES and PARALLEL connections.Roy Ken
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
Related ContentAmp hoursSetting Amp Hours In Battery MonitorLargest Lithium AMP Hour Battery - 2023 Arctic Fox 865How many amp-hours?Battery amp/hour ratings
