Does the amp hour rating double when two twelve volt batteries are used? I understand that they need to be both new so they don't go down to the lowest setting. thanks
Actually you get a little more than double due to the Peukert effect. Effectively cutting discharge for each in half makes both together more efficient. Or put "Peukert" into wiki.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
