- Boon_DockerExplorer IIIA real easy way to find out. Turn on a light in the trailer (when not plugged in to 120 VAC), then switch the disconnect to ON or OFF.
- Off, no power
On, power - Typically 'OFF' would be an open circuit and the battery is disconnected.
If you are plugged in or the RV is in use you should have the switch on. - MrWizardModeratorthink of it as 'battery Connect' relay
on is power
off is no power/disconnect - beemerphile1ExplorerDon't know what switch you are using but correctly it should be open and closed.
Closed = power flows thru
Open = the circuit does not allow power to flow
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
