enblethen
Apr 13, 2017Nomad
The switch has two posts.
One goes to the batteries. It can go to the negative or positive. Many feel negative is better. You would run from batteries, one wire each to one post.
Other post goes to the rig's power distribution panel.
There should be a fuse or circuit breaker at the battery to protect the wiring between batteries and the power distribution panel. It can be either side of the switch.
The break away switch must stay active even when switch is in the off position.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
