- bob_nestorExplorer III
the2sharps wrote:
I tow a 2015 Ford Focus four down. The last step to prepare the car to tow is to disconnect the negative cable from the battery. I mounted a knob style switch under the hood for the disconnect.
I used a knob style switch that came with my Cool Tech wire harness but discovered that it would corrode and fail to make a good connection with the battery. Replaced it with a sealed switch that I got at AutoZone and haven't had problems since. - the2sharpsExplorerI tow a 2015 Ford Focus four down. The last step to prepare the car to tow is to disconnect the negative cable from the battery. I mounted a knob style switch under the hood for the disconnect.
- RoyBExplorer III use these four position BLUE SEA Marine sealed Battery switches... This will give you OFF-BAT1-BOTH-BAT2 then back to OFF again...
The open knife switch looks pretty dangerous to me. Might drop a screwdriver across and blow some fuses somewhere...
Great for adding to a metal battery box
These have the ring terminals on the back for safe hookups to your battery system.
These contacts make before break and are sealed to prevent arcing. Very safe to use...
Available from AMAZON
NOTE: I see the other post is referring to your TOAD Battery system. My comments are more related to a Battery setup system for using multiple batteries etc... Disregard if that is why your asking questions about the different battery disconnect switches...
Roy Ken - I would check to see what you really need to disconnect in the toad. If only one or two fuses get the disconnect assembly from Roadmaster. You would then just turn off what is necessary. Turning off all electric could cause issues with EDM or auxiliary brake control if equipped.
What make year and model of toad?
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 02, 2025
