ianmac23's avatar
ianmac23
Battery Hook-up Question
I am building a new battery box for the two golf cart batteries that I just purchased. I also adding a marine battery cut off switch. My question is if I disconnect the battery once the RV is plugged in to shore power will the 12v items on the RV still work? Can I use my good portable 3-stage charger with the positive hooked to the RV and the negative disconnected?
Thanks for the help
Ian
