ianmac23's avatar
ianmac23
Battery Hook-up Question
I am building a new battery box for the two golf cart batteries that I just purchased. I also adding a marine battery cut off switch. My question is if I disconnect the battery once the RV is plugged in to shore power will the 12v items on the RV still work? Can I use my good portable 3-stage charger with the positive hooked to the RV and the negative disconnected?
Thanks for the help
Ian
  • wa8yxm wrote:
    A Progressive Industries, Intellapower 9200.. now that is one heck of a converter.
    The Intellapower (sic) 9200 is made by Progressive Dynamics, NOT Progressive Industries. ........It's Intellipower.
  • RoyB's avatar
    RoyB
    Explorer II
    This is typical 30AMP trailer wiring configuration...
    AS you can see here the 12VDC Power distribution Panel is ran by both the on-board converter/charger unit and/or a battery.
    If you disconnect the battery when on SHORE POWER your trailer system will still run just fine from the 12VDC power Distribution Panel that is powered by the on-board 120VAC converter/charger unit.
  • prichardson wrote:
    Why would you want to disconnect the batteries when on shore power? Some of the on board chargers(converter) will carry the 12V systems; however, for most it is better that they see a battery. A separate charger would need both its + and - connected to the battery bank.
    If you have a single stage converter/charger and leave the battery connected while on shore power it will boil the battery dry quickly. Don't ask me how I know!!
