Gjac wrote:
Good luck on your new RV. Sounds like you are going camping at least every other week. Being a new camper you probably go in it at least once a week anyway to add things to it, so just check the batteries with a volt meter when you enter. You should read 12.6 + volts if they are fully charged. You will get an idea of how fast they will self discharge. Do you dry camp or go to FHU sites? If FHU they will charge when you plug in. If you dry camp fully charge them when you return home. Batteries will self discharge over time but new batteries like what you have will be fine if you have a battery disconnect switch and use it between your camping trips. I charge mine up in Nov and they sit over the winter with out a charger on them. They sit a month or so sometimes in the summer without a charge. If you post what charger you have you will get more detailed answers. Most batteries die from under charging and the plates get sulfated or overcharging and not checking the water levels.
I happen to have a Victron BMV-712 battery monitor, so I can keep pretty close tabs on energy usage and status. I
JUST came back from the trailer after initially asking my first question. I ran over to fix a problem I found last weekend. Last weekend's trip was an dry camping trip where we stayed for two nights. I plugged into a generator for about 45 minutes midway through the day between the nights; the batteries never dropped below 89% on the trip. I've found that the amount of charging when connected to the tow vehicle is extremely minimal. I did not have any time to top off the batteries after the trip and I'm unable to plug in while the trailer is in storage (at an RV storage lot). I noticed when I got to my trailer today, I forgot to disconnect the batteries last Sunday evening. The state of the batteries were down to 88% according to the VictronConnect app on my phone. I'd imagine that most of my camping will be at facilities that HAVE electricity hook-ups, but not all, like last weekend. I also have a generator, which I can use when dry camping. Unless I'm truly boondocking, most places have a curfew for generator use, so it will be episodic at best when dry-camping. Last weekend I was at a California State Park (Calaveras Big Trees SP).
While I was there at my trailer, I took the water caps off the batteries and they appeared to be full... a slight concave curvature of the water at the base of each fill-port. The water appeared quite clear, seeing the lead panels inside fairly easily. I did not pull out a hydrometer (I haven't purchased one yet).
When it comes to some maintenance, we plan on taking our trailer to the dealer we purchased it from yearly for an annual inspection. During this time, they do a multi-point inspection and repair of any little issue. This includes cleaning the refrigerator coils, the furnace, and the hot water heater. As it seldom gets to freezing here and if it does, only for a few hours in the night, combined with the insulation of the trailer (undercarriage is enclosed and insulated), I don't think I need to winterize it; I've asked many other RVers in the area and none winterize theirs.
