- wbwoodExplorerWhen you add water (distilled water only), make sure you do not over fill it.. if you do, then it can boil over also. Water should jsut be covering the plates...Not to the top of the hole.
- ksg5000Explorer II
chefdc1 wrote:
Yeah, I was looking in all the wrong places! it is a Magnatek Power Plus 6345.
Considering upgrading Best Converters is a good place to start the process. Lots of alternatives .. many switch to Progressive Dynamics 9200 series converters. - rockhillmanorExplorer IIWhen mine smelled like rotten eggs i.e. sulphur smell.
It was the CONVERTOR cooking the battery!!
My Convertor had a blown capacitor and couldn't regulate itself and was raging out of control frying the battery. Had to replace the convertor and of course a new battery.
On some MH's it is located along side the bed. There is your fuse panel, convertor and fan.
Get a reading on what it is putting out. Leave the tester on a good length of time to see if it is climbing past what is called for.
If you can't do it shut your convertor down and disconnect that battery asap. Go up to the CG office and ask them for the number of their local Mobile RV Repair guy. They carry everything you will need on board or get it within the hour and very reasonable prices while you sit back and have a cold one and chill out. Good Luck - chefdc1ExplorerYeah, I was looking in all the wrong places! it is a Magnatek Power Plus 6345.
- chefdc1ExplorerWait, I'm watching a video...starting to have a clue!
- chefdc1ExplorerCables go into wall behind drivers seat...cant follow them after that. I think I've looked everywhere.Is there a hiding spot I do not know about or am I blind? (1997 Class C Damon Hornet, Ford E350).
- CANAMKIDExplorerDave,
Follow the batt. cables, this should lead you to the converter/charger.
Steve - CANAMKIDExplorerX2 On what Roy Ken said.
- chefdc1ExplorerWhere do I find the converter? (Told you I was a newbie!)
- ksg5000Explorer IIBad battery - maybe short which would make battery boil over, maybe neglect from not providing periodic water, maybe bad converter which went bonkers and put out too many volts (low probability).
Your going to need a new battery - should also test your converter to make sure it's putting out correct voltage.
Do you know your which model converter you have? Old fashion converters tend to put out constant voltage which tend to deplete battery water requiring constant replenishment - newer "smart" converters don't deplete battery water very much and are considered wise investment by many RVers as they don't cost much, easy to install, and save batteries.
Hope this helps.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 04, 2026
